[UPDATE ITA] FilmUP (now with TRAILERS URL too)
ABNormal
Post by ABNormal »
I've added (on request) a new option in my script: the TRAILER URL (if available) instead of Web Page URL.
Option can be activated on the right window, as usual.
so this is the new script:
Authors=L. Francisco
Title=FilmUP
Description=Get movie info from LeoFilmUP.it
Site=http://filmup.leonardo.it
Language=IT
Version=1.0.2 - 16.09.2005
Requires=3.5.0
Comments=**Changes**|Pivello: query URL changed|Zandal:  sistemato puntamento a COMMENTS|Pivello: Film site URL selectable instead of FilmUp page URL|dinolib: adapted to v.3.5.0 and little bugfix | ABNormal restarted...|14.04.2005: Fixed infinite loop if description field missing (Pivello)|16.09.2005: Look for new Main Actors data into page; if present select this instead of Cast data (P)|16.09.2005: Added ActorPlusCast option (P)|03.10.2005 ABNormal: Big Posters and Comments again|14.01.2006 ABNormal: Trailer URL
License=*  The source code of the script can be used in   |*  another program only if full credits to              |*  script author and a link to Ant Movie Catalog  |*  website are given in the About box or in       |*  the documentation of the program               |
AlternateURL=0|0|0=Use the FilmUP web site for FieldURL|1=Try to use ufficial movie web site for FieldURL
MezzoVoto=1|1|0=Integer Ratings|1=Ratings with ,5
ActorsPlusCast=0|0|0=Get Main Actors data (if present) otherwise get Cast field|1=Get Main Actors data (if present) and Cast data
TrailerURL=1|0|0=Normal URL page|1=Trailer URL page (if found)
program LeonardoFilmUP;
  StringUtils1;
  TheMovieAddress: string;
  comm: String;
  LineNr: integer;
  BeginPos: integer;
  LineNr := FindLine('Ordina risultati per', Page, 0);
  if LineNr = -1 then
    AnalyzeMoviePage(Page);
    AddMoviesTitles(Page);
    if TheMovieAddress='' then
      if PickTreeExec(Address) then AnalyzePage(Address);
  Line, PreviousLine, NomeHtml, sTemp: string;
  LineNr,PrevLineNr, BeginPos, EndPos, Field: Integer;
  IsMainActors: boolean;
  IsMainActors := false;
  sTemp := '';
  LineNr := FindLine('<font face="arial, helvetica" size="3"><b>', Page, 0);
  if LineNr > -1 then
    //Translated Title
    HTMLRemoveTags(Line);
      //Look for next info
        LineNr := LineNr + 1;
      until (Line<>'')  or (LineNr > Page.Count);
      // Test if 'Trama:' missing
      if ((PreviousLine = 'Data di uscita: ')
      or  (PreviousLine = 'Uscita prevista: ')) and (Line <> 'Trama:') then
        if (copy(Line,1,6)<>'Trama:') then
          Line := 'Trama:' + Line;
      PreviousLine := Line;
      //Look for type of line
      if Line = 'Titolo originale: ' then
        Field := fieldOriginalTitle
      else if Line = 'Regia: ' then
        Field := fieldDirector
      else if Line = 'Produzione: ' then
        Field := fieldProducer
      else if Line = 'Nazione: ' then
        Field := fieldCountry
      else if Line = 'Genere: ' then
        Field := fieldCategory
      else if Line = 'Anno: ' then
        Field := fieldYear
      else if Line = 'Durata: ' then
        Field := fieldLength //Special case: get number only
      else if Line = 'Sito ufficiale: ' then
        Field := fieldURL
      else if Line = 'Attori protagonisti: ' then
        Field := fieldActors;
        IsMainActors := true;
      else if Line = 'Cast: ' then
      else if Line = 'Trama:' then
        Field := fieldDescription
        Field := 0;
      // I have to add this test, for sometimes the description
      // is on the same line as the tag 'Trama'
      if (copy(Line,1,6)='Trama:') and (length(Line)>6) then
        Field := fieldDescription;
        Delete(Line,1,6);
        HTMLDecode(Line);
        //Get values
        HTMLDecode(Line);
        //Special case: Length
        if Field = fieldLength then Line := copy(Line,1,length(Line)-1);
       //Alternative URL case
       if (field = fieldURL) then
         if (Length(Line) = 0) or (GetOption('AlternateURL')=0) then      // if WEB url missing or explicitly requested...
           Line := GetField(fieldURL)  // ...restore FilmUp URL
           Line := 'http://'+Line;
      if Field<>0 then
       if Field = fieldActors then
         if IsMainActors then // Remember Main Actors (if present)
           sTemp := Line;
           if ((GetOption('ActorsPlusCast')=1) and (sTemp<>'')) then
             Line := sTemp + ' Cast: ' + Line
             if sTemp <> '' then
               Line := sTemp;
           SetField(Field,Line);
    until (Field=fieldDescription) or (LineNr > Page.Count);
  PrevLineNr := LineNr;
   //Trailer
if GetOption('TrailerURL')=1 then begin
LineNr := FindLine('">Trailer</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('size="2"><a', Line) <> 0 then Delete(Line,1,pos('size="2"><a',Line));
    //if Pos('DVD', Line) <> 0 then Delete(Line,1,pos('DVD',Line));
    Delete(Line,1,pos('href="',Line)+5);
    NomeHtml := Copy(Line,1,pos('"',Line)-1);
    if (copy(NomeHtml,1,1)<>'/') then
      NomeHtml := '/' + NomeHtml;
NomeHtml :='http://filmup.leonardo.it' + NomeHtml;
    comm := textbetween(GetPage(NomeHtml),'<EMBED SRC="','"');
//HTMLRemoveTags(comm);
SetField(fieldURL,comm);
  //Comments
  LineNr := FindLine('">Recensione</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('Scheda', Line) <> 0 then Delete(Line,1,pos('Scheda',Line));
    NomeHtml :=Copy(Line,1,pos('"',Line)-1);
comm := textbetween(GetPage(NomeHtml),'<font face="arial,helvetica" size="2"><b>','<a class="filmup" href="opinioni.htm">');
comm := textafter(comm,'</b><br>'+#13#10);
SetField(fieldComments,comm);
  //Rating
  LineNr := FindLine('">Opinioni</a>', Page, PrevLineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('Recensione',Line));
    Line := GetLineFromOtherPage(Copy(Line,1,pos('"',Line)-1),'</b> - <img src="');
    if Line <> '' then
      Line := Copy(Line,1,pos('</b> - <img src="',Line)-1);
      if GetOption('MezzoVoto')=0 then
 if pos('.',Line)>0 then Line := Copy(Line,1,pos('.',Line)-1);
      SetField(fieldRating,Line);
  //Picture
    LineNr := FindLine('<img src="locand', Page, PrevLineNr);
    if LineNr > -1 then
      Delete(Line,1,pos('<img src="locand', Line)+9);
      GetPicture('http://filmup.leonardo.it/'+Copy(Line,1,pos('"',Line)-1));
  LineNr := FindLine('href="posters/locp/', Page, PrevLineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('href="posters/locp/',Line)+5);
    Line := GetLineFromOtherPage('http://filmup.leonardo.it/'+Copy(Line,1,pos('"',Line)-1),'<img src="../loc/500/');
    if Line <> '' then
      Delete(Line,1,pos('<img src="../',Line)+12);
      GetPicture('http://filmup.leonardo.it/posters/'+Copy(Line,1,pos('"',Line)-1));
  //DisplayResults;
function GetLineFromOtherPage(address: string; hint: string): string;
  LineNr: integer;
  LineNr := FindLine(hint, Page, 0);
  if LineNr > -1 then result := Page.GetString(LineNr);
procedure GetComments(address: string);
  BeginLine: integer;
  EndLine: integer;
  i: integer;
  Line, Comments: string;
  BeginLine := FindLine('RECENSIONI', Page, 0);
  BeginLine := FindLine('<font face="arial,helvetica" size="2"><b>', Page, BeginLine);
  EndLine := FindLine('<a href="opinioni.htm">Scrivi la tua recensione!</a></font><br><br>', Page, BeginLine);
  for i:= BeginLine+1 to EndLine-1 do
    Line := Page.GetString(i);
    Line := StringReplace(Line, '<br>', #13#10);
    Line := StringReplace(Line, #13#10#32, #13#10);
    HTMLDecode(Line);
    Comments := Comments + Line;
  BeginPos, EndPos: Integer;
  LineNr := 0;
  LineNr := FindLine('FilmUP - Scheda: ',Page,LineNr);
while LineNr > -1 do
  MovieAddress := 'http://filmup.leonardo.it/sc_' + TextBetween((Page.GetString(LineNr-1)), '_', '.') + '.htm';
  MovieTitle := TextAfter(Page.GetString(LineNr), 'Scheda: ');
      While pos ('<span', MovieTitle) > 0 Do begin
      MovieTitle := TextBefore(MovieTitle, '<span', '') + TextAfter(MovieTitle, 'bold;">');
      While pos ('</span', MovieTitle) > 0 Do begin
      MovieTitle := TextBefore(MovieTitle, '</span', '') + TextAfter(MovieTitle, '/span>');
    HTMLRemoveTags(MovieTitle);
    HTMLDecode(Movietitle);
    LineNr := FindLine('FilmUP - Scheda:',Page,LineNr+1);
    if TheMovieAddress='*' then
      TheMovieAddress := MovieAddress
      TheMovieAddress := '';
  LineNr := FindLine('Successivo',Page,LineNr);
  BeginPos := pos('HREF',Line);
  if BeginPos>0 then
    Delete(Line,1,BeginPos + 5);
    EndPos := pos('"',Line);
    MovieAddress := copy(Line,1,EndPos-1);
    PickTreeMoreLink(MovieAddress);
// Questo è il main dello script
  if CheckVersion(3,5,0) then
    TheMovieAddress := '*';
    MovieName := StringReplace(GetField(fieldTranslatedTitle), '.', ' ');
While pos ('[', MovieName) > 0 Do begin
  MovieName := TextBefore(MovieName, '[', '') + TextAfter(MovieName, ']');
    if Input('FilmUP Import', 'Digita il titolo del film:', MovieName) then
      AnalyzePage('http://filmup.leonardo.it/cgi-bin/search.cgi?q='+UrlEncode(MovieName)+'&ul=%25%2Fsc_%25');
    ShowMessage('Questo script richiede una versione più nuova di Ant Movie Catalog (almeno la versione 3.5.0)');
that's all
ABN
PS: next work (if i'll be able): asianworld with subs link....
ABNormal
Post by ABNormal »
antp wrote:Thanks
i thank you.
gikem
Trailers url?
Post by gikem »
ENG: they are desolated. but I have not understood where the link is found. it is possible to save the trailer in the catalogue as for the images?
ITA: sono desolato. ma non ho capito dove si trova il link. è possibile salvare il trailer nel catalogo come per le immagini?
ABNormal
Re: Trailers url?
Post by ABNormal »
ENG) no, the direct link is in the URL field.
you can watch 'em or, using something as Free Download Manager you can download them. A direct downloading is useless for most users (i suppose) so i didn't try to do it.
ITA) se presente, il link al video è messo nel campo URL. basta fare Apri File per vederlo o, usando qualcosa del tipo di Free Download Manager, lo puoi scaricare. Non ho neanche provato ad importare i video direttamente, che allungherebbe i tempi di ricerca inutilmente, almeno x la maggior parte degli utenti.
ABN
