I can't load any information from internet!
nidzesi
Post by nidzesi »
I have a movie Rush Hour and I want to download more informations about it from internet and I go to Get information/From script. I have a list of scripts available but when I click twice on any script I always get the same message "No movie found". I always use IMDB because I know that it is the best, but any script does not work.
Can you help me??
So for anything that you type all the scripts say that they do not find movies? :??: Maybe you have a Firewall or something similar that modify the structure of the pages? (e.g. by removing ads, filtering some contents, ...)
You have the latest version of AMC ?
nidzesi
It's OK!
Post by nidzesi »
I solve the problem! I have just download last version of AMC and it works fine! Thanks for the answer!
