[REL] Zinema [Es] - Primera versión
gilistico
Post by gilistico »
En algunas ocasiones tiene esa pelicula que no encontramos en otros lugares.
Zinema (ES).ifs
Authors=gilistico
Title=Zinema (ES)
Description= Movie importation script for "Zinema + Google" (Spain)
Site=www.zinema.com
Language=ES
Version=1.0
Requires=3.5.0
Comments= Primera version
program zinema;
	StringUtils1;
function MyTrim(var S: string): string;
   	n,len,  space: Integer;
   	c: char;
   	t: String;
   	len := length(s);
	for n:=len downto 1 do
		c := Copy(s,n,1);
      		if(c= #32) OR (c=#9) OR (c=#13) OR (c=#10) then
			len := len-1
		else break;
   	space := 2;
   	t := '';
   	for n :=1 to len do
      		c := Copy(s,n,1);
      		if(c= #32) OR (c=#9) then
         		if space > 0 then
            			continue;
         		c     := ' ';
         		space := 1;
      		else if (c=#13) OR (c=#10) then
			if space > 0 then
            			continue;
			space := 1
		else    space := 0;
		t := t + c;
	s := t;
	result := t;
   n,len, tag, space: Integer;
   c: char;
   t: String;
   tag := 0;
   space := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if (c= #13) OR (c=#10) OR (c= #32) OR (c=#9) then
         if space = 1 then
            continue;
         c     := ' ';
         space := 1;
         space := 0;
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
   	LineNr, Count: Integer;
   	PosIni, PosFin: Integer;
   	Line, Line2, SubLine: string;
   	Title, DirURL: string;
   	txtTemp: string;
   	LineNr := FindLine('</b> - no produjo ningún documento.<br>', Page, 0);
   	if LineNr <> -1 then
      		ShowMessage('No se ha encontrado ningún registro');
   Count  := 0;
   LineNr := 0;
   While TRUE do
      LineNr := FindLine('<p class=g><a class=l href="', Page, LineNR+1);
      if LineNr = -1 then
         LineNr := FindLine('<b> Siguiente </b>', Page, 0);
         if LineNr = -1 then
            break;
           Line    := Page.GetString(LineNr);
         Line    := TextBetween (Line, '<td nowrap nowrap>', '>');
         Address := TextBetween (Line, 'href=', '>');
         if Address = '' then
            break;
         Address   := 'http://www.google.com' + Address;
         LineNr := 0;
         continue;
      Line2  := Line;
      DirURL := TextBetween (Line, '<p class=g><a class=l href="', '">');
      Line := Line2;
      Title  := TextBetween (Line,'<p class=g>', '</a>');
      Line   := TextBetween (Line2,'LA BUTACA -', '</a>');
      if Line <>'' then
         Title := Line;
      DeleteTags(Title);
      HTMLDecode(Title);
      PickTreeAdd(Title, DirURL);
      Count := Count +1;
   if Count = 0 then
      ShowMessage('No se han encontrado registros');
            AnalyzeMovie(Address);
procedure AnalyzeMovie(Address: string);
     	Page:     String;
     	LineNr:   Integer;
   	LineEnd:  Integer;
     	Line:     string;
     	Item:     string;
     	Comments: string;
     	Line := '';
   	Comments := '';
     	Page := GetPage(Address);
   	// Cartel
	Item := TextBetween(Page, 'src="../../', '"');
 	if Item <> '' then
		GetPicture('http://www.zinema.com/'+Item );
	Page := StringReplace(Page,'<font color="#800000" face="Arial"><small><strong>  </strong></small></font>','');
    	// Titulo español
   	Item := TextBetween(Page, '<font size="4">', '</font>');
	if Item <> '' then
      		Item := DeleteTags(Item);
      		HTMLDecode(Item);
		SetField(fieldOriginalTitle,Trim (Item));
   	// Titulo original
	Item := LeeDato(Page, 'original');
   	if Item <> '' then
   	// Dirección
	Item := LeeDato(Page, 'Dirección');
   	if Item <> '' then
   	// Pais
	Item := LeeDato(Page, 'Nacionalidad');
   	if Item <>'' then
   	// Año
	Item := LeeDato(Page, 'Año');
  	if Item <>'' then
   	// Duración
	Item := LeeDato(Page, 'Duración');
	if Item <>'' then
      		SetField(fieldLength, TextBefore(Item,' m',''));
   	// Genero
	Item := LeeDato(Page, 'Género');
   	if Item <>'' then
   	// Interpretación
	Item := LeeDato(Page, 'Intérpretes');
   	if Item <>'' then
      		SetField(fieldActors, Item);
   	// Sinopsis
	Item := LeeDato(Page, 'Sinopsis');
   	if Item <>'' then
   	// Guión
	Item := LeeDato(Page, 'Guión');
   	if Item <>'' then
		Comments := Comments + 'Guión: ' + Item + #13#10;
   	// Fotografía
	Item := LeeDato(Page, 'Fotografía');
   	if Item <>'' then
		Comments := Comments + 'Fotografía: ' + Item + #13#10;
   	// Música
	Item := LeeDato(Page, 'Música');
   	if Item <>'' then
		Comments := Comments + 'Música: ' + Item + #13#10;
   	// Montaje
	Item := LeeDato(Page, 'Montaje');
   	if Item <>'' then
		Comments := Comments + 'Montaje: ' + Item + #13#10;
   	// Estreno
	Item := LeeDato(Page, 'Estreno');
   	if Item <>'' then
		Comments := Comments + 'Estreno en España: ' + Item;
	if(Comments <>'') then
function  LeeDato(Page: String; Texto: string): string;
	Line: String;
   	Line := TextBetween(Page, Texto +'</strong>', '<font color="#800000"');
	Line := StringReplace(Line,#13#10,' ');
	Line := StringReplace(Line,'<tr>',#13#10);
      	HTMLRemoveTags(Line);
      	HTMLDecode(Line);
	Line := MyTrim(Line);
      	result := Line;
       	Input('Zinema', 'Titulo de la pelicula:', MovieName);
        AnalyzePage(UrlEncode('http://www.google.com/custom?num=100&hl=es&rls=GGLD,GGLD:2005-49,GGLD:es&as_epq=' + MovieName + '&lr=lang_es&as_occt=title&as_dt=i&as_sitesearch=www.zinema.com'));
gasofa
Post by gasofa »
Yo me quedo flipao con tu trabajo, colega.
MUCHAS GRACIAS
Nota: Aunque en realidad el 99% de las veces utilizo el Cineol, te lo curras una barbaridad. Por cierto no podrias hacer un scripts con varios scripts por ejemplo comprobando si no tiene duracion lo busca en otro scripts, si la caratula es menor de 10 kb la busca en otro, o incluso la caratula mas grande de 3, 4 o los scripts que sean. Para tener una buena caratula.Y así completar por ejemplo una pelicula con un script que busque todos los datos y encima la mejor caratula.-
Saludos.-
gasofa
Post by gasofa »
Ah!! perdona. FELIZ AÑO NUEVO!!!!
gilistico
Post by gilistico »
Mi consejo es que uses IMDB (ES).ifs
Para todos los datos de la pelicula, a excepción de caratula, sinopsis y críticas.
En cualquier caso la duración (formatos, bitrates, etc.) de la película es mejor extraerla directamente del fuente que tengas (Divx, DVD, mpeg, etc.), es mucho más exacta.
Desgraciadamente Antp :ha: :cool: ;) no nos ha dejado ninguna función que se pueda utilizar en el escript para controlar la caratula (cover, poster). Ni siquiera puedo saber si hay ya una cartula en el catalogo o si la caratula que he encontrado ha sido cargada. Supongo que para avanzar por este camino habrá que lanzar programas externos.
Saludos.-
Sobre la caratula, no es posible, pues faltan herramientas (funciones para usar en el script), salvo que se utilicen programas externos. En cualquier caso, por programa no se puede seleccionar entre varias caratulas que corresponden a los carteles de varios paises; si se hiciera automático, correríamos el riesgo de coger un cartel coreano en lugar del español que deseamos.
Creo que tampoco es posible la concatenación de scripts, por lo que habría que hacer un macroscript que incluyera el codigo de muchos, y no me parece muy correcto.
Supongo que habrá que esperar a que se mejoren los scripts y a que aparzcan nuevas versiones de Ant Movie Catalog :cool: que nos traigan nuevas funcionalidades. ;) :grinking:
Feliz 2006.
airmuze
Post by airmuze »
perdonen que quiza mi pregunta sea tonta pero como hago para agregar este script a mi soft ya andando??? no entiendo mucho de sto y necesito que me expliquen como si fuera un nene porque soy nueva en esto
no tengo ni idea y quiero scripts en castellano porque el que usaba de yahoo en español no me anda mas
les super agradecere
saludos
gasofa
Post by gasofa »
Buenas airmuze y bienvenida al foro, aunque ultimamente está bastante parado.-
Lo que tienes que hacer es ir a: http://www.antp.be/temp/scripts/ de aquí te bajas todos los scrips españoles (ES) y borras todos los que tienes en la carpeta scrips del programa en tu ordenador, de esta manera tendras todos los scrips actualizados y en español.-
Despues lo que tienes que ir es probando, para ver si funciona o no, porque hay veces que sobre todo nuestro "colega" gilistico hace mejoras o cambios y es ahí donde te tienes que venir al foro y ver si hay algun cambio.-
Ahora mismo hay algunos que no chutan bien, por ejemplo el que yo uso siempre que es el cineol, pone unas cosas raras en el cuadro de los Oscar's de la peli y eso, hay otros que tengo oido que no ponen la caratula, pero ya te digo que en cuanto se enteren los "artistas" nos lo solucionan.
GRACIAS a ellos y espero haberte ayudado algo.- ;)
I do not understand the message, but all the scripts that were on that address before last week are included in the latest AMC release, since I updated the package on last sunday ;)
gasofa
Post by gasofa »
¿¿alguien me puede traducir que es lo que ha dicho antp??? porque no m'enterao de na, pero de na de na.-
folgui
Post by folgui »
!Hola!
Lo que quiere decir antp (what antp says translated to spanish) :
Todos los scripts que estaban en esa url la semana pasada están ahora incluidos en en el paquete de la última versión de AMC, paquete que ha actualizado el pasado domingo.
Saludos, folgui.
You forgot to translate that I did not understand what is said in his message :D (since I do not understand spanish, I only guess the global meaning of the messages when they are simple)
gasofa
Post by gasofa »
Ok folgui, gracias.
Buff, otra vez ha dicho algo y "forgot"¿eso es prohibido? :??: :??:
icecubix
Post by icecubix »
gasofa wrote:Ok folgui, gracias.
No, "forgot" es "olvidado". Dice que os habeis olvidado de traducir el hecho de que antp no entiende el español y le cuesta mucho deducir lo que decimos.
(in english)
"forgot" equals "olvidado". Antp says you have forgotten to translate the fact that he don't understand spanish and it's very hard for him to deduce what we say (my english it's not very good, sorry).
gasofa
Post by gasofa »
Ok icecubix, GRACIAS.-
icecubix wrote:Antp says you have forgotten to translate the fact that he don't understand spanish and it's very hard for him to deduce what we say (my english it's not very good, sorry).
It's folgui that forgot, not gasofa :D
RANICUAJO
Zinema.com ha dejado de funcionar??
Post by RANICUAJO »
Muy buenas. ;) Soy nuevo por akí, y quisiera agradecer el curro que se a pegao antp con su programa (una gozada), y a los que os lo currais creando y arreglando scripts. :grinking:
El caso es que ultimamente el script de zinema (que es el que mas uso, ya que tiene toda la información que necesito) no me encuentra registros para ninguna película (incluso las que ya bajé antes) ¿sabeis si ha dejado de funcionar o ha cambiado la web o algo? :cry: Lo que mas me mola de este script, es que baja junto a los intérpretes, el nombre del correspondiente personaje. :cool:
Si se arregla la cosa, se podría meter algún arreglo al script para que no de error por los acentos (la dichosa página es sensible a ellos) :??:
Xalu2 y muchas thank yous
folgui
Post by folgui »
¡Hola!
Efectivamente, han cambiado algunas cosas, al menos en la página de resultados, que yo haya visto, por eso no funciona correctamente.
Cuando tenga tiempo, le echaré un vistazo a ver si lo corrijo.
Saludos, folgui.
RANICUAJO
Post by RANICUAJO »
Saludos, folgui.
Gracias Folgui :wink:
No tengas prisa, q podemos esperar :o
Xalu2
RANICUAJO
Post by RANICUAJO »
Esto... :??: perdonar por la insistencia, pero este script sigue sin funcionar y le tenía cariño a esta página :hihi:
Taluego :grinking:
