picturenames, movielist_1.jpg, movielist_2.jpg etc
siski
Post by siski »
When i export to html, all the images are named like above, so
and so on.
the original pictures are stored in C:\Program Files\Ant Movie Catalog\Catalogs and the html file in the same folder, buth the program
does not seem to uses the pictures. I used this program about one year ago and i remember it whas a setting, but i don't see it. :sleep:
I just want to keep the original names when exporting.
Maybe somebody is willing o help?
TIA
It is not possible, and has never been possible, as far as I remember.
siski
Post by siski »
Surely it has been working:
pls have a look at:
http://www.nikolaj.demon.nl/movielist/movielist.html
When you right click on a picture, you'll see the original file name.
I uploaded only the orignal pictures + the html file
Isn't that one of the templates that use AMC's XML file format? Then it is not a HTML exportation, it directly uses AMC catalog, so you have to upload the pictures of the catalog rather than export pictures.
siski
Post by siski »
<!-- Movie Template #2 - Created By Twink - TwinkMan666@hotmail.com      -->
<!-- Made for Ant Movie Cataglog http://www.buypin.com/moviecatalog.php  -->
<!-- Based on my old template with lots of ideas from Willspo's Template -->
<!-- Keep up the good work guys!!!                                       -->
<!-- LastUpdated: 17/10/02  Version BETA 0.5                             -->
<!-- Start of Variables -->
This is the one
Then I do not see how it could use original picture names, since the program never worked this way for the HTML export...
siski
Post by siski »
As I stated before, it was almost a year ago that i used your program. I have no clue what i have done, but it did work at that time. Trying to figure it out.
Thanks for trying to help, much appreciated.!!!!
