Im trying to modify the IMDb script so that i can search/add actors but with no luck; beeing not much of a programmer i was wondering did anyone else try that ? Can anyone point me what variables need to be changed ? For start i belive (though not 100% sure) these are the sections that must be modified:
/ ***** analyzes the results page that asks to select a movie from a list *****
PageText: string;
Value: string;
PageText := GetPage(Address);
if pos('<title>IMDb', PageText) = 0 then
AnalyzeMoviePage(PageText)
ShowMessage('No movie found for this search');
Exit;
Value := TextBefore(PageText, '<ol>', '<b>');
if Value <> '' then
HTMLRemoveTags(Value);
HTMLDecode(Value);
PickTreeAdd(Value, '');
Value := TextBetween(PageText, '<ol>', '</ol>');
PageText := RemainingText;
until not AddMovieTitles(Value);
Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
if Value <> '' then
PickTreeMoreLink('http://us.imdb.com' + Value);
AnalyzeResultsPage(Address);
Value := TextBetween(TextBetween(PageText, '<ol>', '</ol>'), '<li>', '</li>');
if Value <> '' then
AnalyzeResultsPage(TextBetween(Value, '<a href="', '">'));
end;Code: Select all
// ***** adds the titles contained in <ol>'s items *****
Value: string;
Address: string;
Result := False;
Value := TextBetween(List, '<li>', '</li>');
List := RemainingText;
while Value <> '' do
Address := TextBetween(Value, '<a href="', '">');
HTMLDecode(Value);
PickTreeAdd(Value, 'http://us.imdb.com' + Address);
Result := True;
