Sorting by borrower in Loans window doesn't work
bmm
Post by bmm »
As the subject says when sorting by borrower in Loans window it doesn't work as expected. It seems to be sorting partially by numbers (except that 11, 12, 13 etc. comes between 1 and 2 and so on) instead of borrowers.
AMC 3.3.0 (10/06/2002)
OS: Windows 2000 SP1
Well you are right, it is a bug.
I will correct it as soon as possible.
Thanks ;)
