Hi...
I just wanted to ask if you looked into that small problem with the Report Designer, where the option to rotate something 180º doesn't work.
We talked about it a few months ago (I think), and you said you'd look into it when you'd have some time...
I'd like to know if there's any chance to make this work... because if there's not, I'll jus use the program as it is.
If there's a chance to fix this, please tell me so I will wait a bit longer to print those reports.
Thanks a lot!!
Gastón
Report Designer
I did not found how to do it easily.
I will continue to search if I have time but I do not know when I'll have time for that.
This report designer was not made by me so it is quite complicated to make changes. For the 270° it was quite easy (even if it took me nearly a whole day) because it was similar to 90° code. But it seems that I cannot modify easily this code for 180°.
El Ga
