HTML export of movies with duplicate numbers
hansj
Post by hansj »
Hello forum,
I have several movies on one DVD. Each of them share the same movie number.
When I export my database to HTML with the combined and individual templates, I will only get individual informations for the first registered movie number.
Ok, an example, I have a DVD containing movie A,B and C, all sharing the same number.
The export will always generate individual informations for movie A, but the complete index still contains the individual titles of movie A,B and C.
So the individual infos are always from movie A.
Is there anything I'm missing here, or is this a feature? :??:
Thanks for your help,
hans
BTW: This program is really cool!!
It is a known bug, I have to correct it :/
Until then, the only solution is to specify in the Preferences that you want to use title rather than number for individual files.
hansj
Post by hansj »
Hi Antp,
thanks for the quick reply!
Can you point me to the location in the preferences?
Somehow I can not find that option...
Cheers,
Hans
hansj
Post by hansj »
ok, just found that option:
tools->preferences->export:
"Individual pages and pictures file name style" : Movie title ;)
That was easy..
