MPAA Ratings???
WPLYNCH
MPAA Ratings???
Post by WPLYNCH »
Does anyone know of a way to import MPAA ratings? Other than that, this program ROCKS and is the best out there!!!!!
KUDOS to the programmer!!! Way to go!!!!
Will :)
Thanks ;)
for MPAA (from IMDB I guess), it should not be too difficult to modify the script to put this rating somewhere in the "comments" field.
I should try ot do that when I've few time.
zion
Post by zion »
Has this been done yet it's the only thing I would like in this already awesome program
