Carekter Problem
Maca
Carekter Problem
Post by Maca »
Hallo Ich kan keine englisch.
Ich Hoffe ihr könnt mich verstehen.
ich habe problem mit renemar,die umlaut buchstaben werden doppelt angezeigt also eine datei mit umlaut und eine datei mit europer schrift aber das europer schrift ist leider beschädigt.
Und so bringt meine pc föllig durcheinander alles wird doppeltangezeigt,
bitte um hilfe.
mfg
Sorry, I only understand English & French :/ Using an an online translator I can't understand what you wrote, the translation does not seem to work very well...
Hallo,
Traurig, verstehe ich nur englisches u. Franzose :/ Das Verwenden ein on-line-Übersetzer, den ich nicht verstehen kann was Sie schrieben, die Übersetzung, scheint nicht, sehr gut zu arbeiten...
Maca
Post by Maca »
Hello I kan no English.
I hope it can me understand. I have problem with renemar, those umlaut letter doubly indicated thus a file with umlaut and a file also euroby writing however euroby writing am unfortunately damaged. And in such a way my PC brings everything is double-indicated foellig in disorder, please around assistance.
mfg
euroby = ??
You mean that if you want to use a "¨" you get "¨¨" ? It happens only in Ant Renamer ? I know that there were some viruses and troyans that caused this problem.
Maca
Post by Maca »
i not anderstand :??: I can speak german.
I have problem is to files
wan files is Dolaşalım wan files is Dolasalim wan files is bad.
Maca
Post by Maca »
your program destroys the,öüÄ in my pc every time itry to correckt the mistake,i have two kind of letters on my screem first the european art and second the art of öäüŞ
Hier is demo
http://www.sro.at/bildupload/images/fehler.gif
Since the program supppots unicode it should work fine, I tested it with lots of special characters and I had no problem.
Which Action do you select in the program, and which params do you set for this action?
Maca
Post by Maca »
as I already in the picture did not indicate, I make anything as which one make mash. but datein is 2 one of it is broken always.
Maca
Post by Maca »
hier habe ich zwei datein als demo gemacht probiern sie selbst die datein umzubennen.
I have 2 demo for you,you can this file rename and sehe problem.
http://rapidshare.de/files/9509956/test.rar.html
And what action do you select in the list? If I try "string insertion" for example, it works fine
Maca
Post by Maca »
ok hier ist eine film demo bitte gucken sie sich das an.
hir is demo of video.
http://rapidshare.de/files/9634151/test.avi.html
When I do the same it seems to work :??: Can you send me your file "Renamer.xml" ? (in c:\program files\ant renamer by default)
Maca
Post by Maca »
On my PC it works fine... it changes the names correctly.
Maca
Post by Maca »
i have send you demo you can see have problem,dies problem have my frand,and I
you window is ?
