Printing picture on the cover
Teron
Post by Teron »
some times picture on the cover prints with filled black color, convert with ACDsee 2.42 .jpg->.jpg was not solve this problem, but PhotoShop 5.0 can save good picture and ANT prints it as a good picture, what is was? Bad format of .jpeg? In PrintPreview picture was good
Sorry for my english
I do not know what causes that. Maybe it could depend on the printer driver if the preview is OK :??:
Teron
Post by Teron »
So, if nobodey ever seen this problem, I think, that problem is in my comp or system.
Teron
Post by Teron »
Just test this problem: Exit ANTCatalog, Run again, and try print - probem disappear. Can you solve this problem?
I cannot solve a problem that appear randomly, and that only appears on paper and not on screen :/ Even more, the printing engine was not done by me: I use a ready-to-use component for that.
Teron
Post by Teron »
I guess that it is annoying since you cannot know if it will work before seeing what has been printed.
A solution would be to install a PDF printer (e.g. CutePDF), print to the PDF, and then print the contents of the generated PDF if it is correctly displayed.
