Bug in SQL-Export
bcn
Bug in SQL-Export
Post by bcn »
I usually export my movies in a sql-database.
In earlier versions the sql-export worked like a charm, but
since the last two or three versions the option "sql-date-format" for exports does not work anymore. Regardless what is in this field (for example yyyy'-'mm'-'dd), dates are always exported in windows-format (11.11.2005) and this makes mysql get some crazy dates ...
Can you please check this and fix it.
Thanx alot.
greetings from germany
bcn
You have version 3.5.0.2 ? For me it seems to work fine.
bcn
Post by bcn »
Yes, I have Version 3.5.0.2 from 2005.05.29. I installed your latest Package from 2005.10.15.
If I remember correctly, the Problems came with the first version of 3.5.02 from 2005.05.29.
I tried many variations of format in the "sql-date-format", with " as a separator as well as ' - nothing helps - The Date export is always in the standard Windows form (12.11.2005 with my windows).
I also tried a new, empty Catalog and created only one entry, with the same results.
I have Windows XP Pro german, SP2 with all Fixes installed.
I just made some further experiments:
- I changed the date format in Windows to "2005-11-12" with the effect that I get an empty date-field in the sql-export.
- I changed the "sql-date-format" field to "", the same effect - empty date-field in export
- I changed back to my Windows-Date-format and the "sql-date-format" field to 2005'-'11'-'12, with the same effect that the date-field in sql is empty .... now thats strange - before I changed settings, the sql-date was in windows-format with exact these settings ...
I hope you can help me ... please
thanx
bcn
You type 2005'-'11'-'12 in the field? I guess that you mean yyyy'-'mm'-'dd like in you first post.
On my Windows the date format is yyyy-mm-dd and if I put for example dd'/'mm'/'yyyy in the preferences, the "added date" field in sql export follow this format.
bcn
Post by bcn »
of course i typed yyyy'-'mm'-'dd in the field - sorry for this ...
can it be that it has something to do with the reading/writing of xml-files?
Is it possible that I have installed something that changes the behavior of reading or writing of xml-files? But I save the Movie-Catalog in XML-Format also and this seems to be ok.
I browsed through the prefs.xml file and notived that under "export" the SQLDate Entry was always empty even if i used some of the predefined entries in the options-window.
I then changed the entry manually to SQLDate="yyyy'-'mm'-'dd", and when I rechecked the prefs.xml file the entry changed to the following:
<Export LoadTemplate="-1" LineBreak="<br>" ForcePicSizeW="-1" ForcePicSizeH="-1" SQLDate="yyyy'-'mm'-'dd" RememberLastFile="-1" LastFile="BCN_Movies.sql" OpenExportedFile="0" ExpFileStyle="0" ExpFileExt="" AddZeroes="-1" CopyPictures="-1" CopyPicturesNew="-1"/>
Is this correct?
The SQL-Export now has a date in the field, but like before in the Windows-FOrmat dd.mm.yyyy ...
I will now try the program in another windows and see what I get there ...
The program has its own XML engine so I do not think that the problem could come from there... It is really strange :/
bcn
Post by bcn »
I found the problem!
I installed the program on another pc and tried the export with your demo-database and the date-format was correct.
Then I opened my database and exported it to sql - date-format correct also.
Next I copied the prefs.xml from the newly installed version to the program dir. of my pc - and it works!
The Date-Format is correct now, the disadvantage is that I have to redo all the configuration-settings.
So there must be an error in the prefs.xml file - I looked at it and compared it with the "empty" prefs-xml file - I could not figure out an obvious error ...
If you are interested I can mail you the defect prefs.xml file.
bcn
Yes it could be interesting to prevent the bug in the future ;)
