IMDB Script doesn't work like it should be
zile
Post by zile »
Hi
For me IMDB script doesn't work anymore, like it should be. In the description selection, there ought to be 2 or more plot outline for the movie. Now there is only one all the time (it seems that the script doesnt display plot summary anymore). Is there something I can do about it. Thx for the help and awesome program.
Bye
I guess that IMDB made few changes...
I've updated the scripts, it should work now :
ftp://ftp2.antp.be/antp/software/amc_scripts.zip
I will update the other files (install package etc...) later.
What can I say. You simply are :grinking:
