Group does not remain expanded
crocodilu_q
Post by crocodilu_q »
I noticed an annoying behavior of AMC. I don't know if it was intented to work like this or if it just a glich :)
Here it goes: Let's say I have some movies and I group them by Media Label (in my case, these are episodes and the media label is the series name). I expand one group, select one movie and run a script to gather info on tv.com. When the script is finished, the window refreshes and the group is again un-expanded. I would like it to remain expanded like it was before calling the script. This very annonying to expand it again and to scroll to where I was before.
Is it possible to fix this ?
Thank you very much :)
PS: Sorry if this post had to be posted in some other category.
There is an option to expand all groups by default; but the group containing the selected movie could be expanded anyway: I'll check that
crocodilu_q
I know about that option, that only expands all the groups.
The problem is that the current expanded group (just one group), automatically closes after the script is finished
