Script field ?
deathbyaclown
Script field ?
Post by deathbyaclown »
I couldnt find a field for the script of a movie (so the writer of it).... Is there a reason for keeping this out ?
THX
A reason, yes and no: fields were selected very long time ago, and I haven't added new ones since then. In a future version I plan to rearrange the way the fields are displayed and I was waiting that for adding new fields.
deathbyaclown
okidoki - thx for answer :grinking:
