Improving the Import
deathbyaclown
Post by deathbyaclown »
I have a suggestion for future versions :)
It would be perfect, if one could save a kind of template for the import of csv data. Currently, for every import one has to determine names of the columns. It would be cool, if one could create a skeletton and reuse it.
e.g. that the first columns is the number, the second the originaltitle, the third the actors or whatever.
THX
In next version it will already automatically recognize columns if field names are specified in headers (which can be the case for a csv file that was previously exported)
deathbyaclown
fantastic :grinking:
