2 suggestions
Kyf
2 suggestions
Post by Kyf »
Hi and good job with your soft :grinking:
2 suggestions:
- Have you a more precise idea about the audio management for further version ?
It would be great to have a list like that (with listbox for each line):
French | DD 5.1
French | DTS
English | DD 5.1
and another list for subtitles
- Is it possible to download the data from the DVD on the player ?
For the audio list, it will probably not be possible yet in the 4.0 version, it will be for later
To get the information from a DVD I need to find how it has to be done :D So when I know that I will add it quickly I think.
