[REQ]
dwdviper
[REQ]
Post by dwdviper »
I wonder if someone can help me. I love the web based php script that has been created for being able to search movies online and am incorporating this into my own site.
The problem i am having is that I want to use the XML file created by the catalogue to use as an Access DB.Normally XML can be imported into Access but for some reason there some to be some issues with the data layout in this XML file. :??:
Could anyone assist? I am working on an asp version of the web front end and would be willing to share with others if i can overcome this.
Thanks :p
