How to check existing of picture, assigned to movie
Falc0nMan
Post by Falc0nMan »
I want to write script for checking empty fields (Description, Length and Picture) on every movie and setting one of fields (Resolution).
if (GetField(fieldDescription)='') then
MovieMark := '=';
if (GetField(fieldLength)='') then
MovieMark := MovieMark + '*';
BUT I can't check existing the picture.
GetField(fieldPictureName)
GetField(fieldPictureSize)
GetField(fieldPicture)
nothing of above doesn't work... :(
Can I check this field in script???
Falc0nMan
Russia
There is nothing made for that unfortunately. It's one of the feature that I really should add, since it is not difficult to add functions to check/delete/export/import pictures
