new script for beyazperde.com? (Turkish Movie database)
muzur
Post by muzur »
Can someone try to write a script for this site. I couldn't handle it. URL is as follows:
http://www.beyazperde.com/hizliarama.asp?keyword=
Thanks a lot.
Muzur
tiufang
here the one i use
Post by tiufang »
a quick and dirty solution by modifying the imdb script, but it works:
// GETINFO SCRIPTING
// Imports Turkish Titles from beyazperde.com
 *      IMDB (US), http://us.imdb.com              *
 *  (c) 2002 Antoine Potten    antoine@buypin.com  *
 *  Improvements made by Danny Falkov              *
 *  Improvements made by Kai Blankenhorn           *
program TurkishTitle;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  if pos('<title>beyazperde.com - H?zl? Arama', Page.Text) = 0 then
    AnalyzeMoviePage(Page)
    LineNr := 0;
    LineNr := FindLine('<td class="metin3">Filmler</td>', Page, LineNr);
    if LineNr > -1 then
      PickTreeAdd('Filmler', '');
      AnalyzePage(Address);
  BeginPos, EndPos: Integer;
  // Original Title & Year
  LineNr := FindLine('<title>beyazperde.com - ', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('<title>beyazperde.com - ', Line);
    if BeginPos > 0 then
      BeginPos := BeginPos + 24;
    EndPos := pos(' / ', Line);
    if EndPos = 0 then
      EndPos := Length(Line);
    HTMLDecode(Value);
  SetField(fieldOriginalTitle, '');
  SetField(fieldUrl, '');
  DisplayResults;
  StartPos: Integer;
  TempPos: Integer;
    LineNr := LineNr + 1;
    TempPos := pos('<img src="', Line);
    if TempPos < 1 then
      StartPos := pos('<a href="', Line);
      if StartPos > 0 then
        Startpos := Startpos + 9;
        MovieAddress := copy(Line, StartPos, pos('" class=metin2>', Line) - StartPos);
        StartPos := pos('<b>', Line) + 3;
        MovieTitle := copy(Line, StartPos, pos('</b>', Line) - StartPos);
        StartPos := pos('/ ', Line) + 2;
        MovieTitle := MovieTitle + ' - ' + copy(Line, StartPos, pos ('<br>', Line) - StartPos);
        HTMLDecode(Movietitle);
        PickTreeAdd(MovieTitle, 'http://www.beyazperde.com/' + MovieAddress);
  until pos('filmden', Line) > 0;
  if CheckVersion(3,4,0) then
//    if MovieName = '' then
//      MovieName := GetField(fieldTranslatedTitle);
    if Input('Turkish Title', 'Enter the original title of the movie:', MovieName) then
      AnalyzePage('http://www.beyazperde.com/hizliarama.asp?keyword='+UrlEncode(MovieName));
tiufang
Post by tiufang »
by the way...
it only imports the translated title, as i use the other information from imdb.
i'm working for a full information import from beyazperde.com.
i'll post it here if i get any results with it.
I edited your message to add [code] and [/code] tags around the script, it is better like that ;)
When you create or modify a script you can add your name (and remove mine if it is a script that you fully created) in the comments at the top of the file.
muzur
Post by muzur »
@tiufang
Thanks for your work. I will try ASAP. I think besides translated title description (plot) will be enough for now.
Thanks again for your effort.
muzur
Post by muzur »
Well. Copied and pasted the script to a new file named beyazperde.ifs. Tried to run the script. At the end what I got was as follows:
In the "Get Information from script" window Translated Title is checked and at the value field it reads "Hızlı Arama</title".
Any clues?
Regards[/img]
hmm...
i think there was a problem with the page. when some of the tags are not closed properly, you may encounter such problems. I come across these kind of problems in the description part of the movies the most, especially when <a> tag is not closed properly: </a (note the missing >)
I see <title> tag is improperly closed in what you get: </title
perhaps there was a temporary problem, and the page may not be completely downloaded.
does the problem still continue? (try searching for different movies..)
since the scripts depend on strict page structure, when the site changes the structure, scripts should also be changed. perhaps sites should provide some movie db files whose structures won't change? :)
anyway, let me check it again...
muzur
Post by muzur »
well.. checked with five different movie names getting same error result.
ok... it may possibly be due to the turkish characters, the full script is about to finish, i tried to avoid using turkish characters in the full script,
so you can try it, tell me which parts don't work for you...
tiufang
Post by tiufang »
you may take a look at for the full script at:
http://ada.cc.metu.edu.tr/amc/Beyaz%20Perde.ifs
this should be working now. it works for me, at least.
by the way, ant, it's created by modifying your imdb script (since i had no idea how to write a script for amc :) ), so i think your name should be left there...
amc, good program, keep up the good work! :)
tiufang
Post by tiufang »
Nice, I'll include that with the program (maybe only the "full with pic" version)
muzur
Post by muzur »
Well.. Great job.. Working very well.. All the three scripts.. Thanks a lot :)
