Really Cancel
deathbyaclown
Really Cancel
Post by deathbyaclown »
What I like to have in future release is that if you press Cancel in the title field for importing a movie, the whole import process is stopped. Now it starts to connect an displays an empty result because I pressed Cancel.
THX
The problem is that in some scripts a click on "Cancel" means "skip this step", when it asks several things.
DRAG@N
Post by DRAG@N »
I think an option for managing this title box would be very practical, and should be generalized with all scripts.
For example, I like the fact that the request box is displayed again when the title is not found (it's always better than a blank results page). The CDDB script is a good exemple : if you entered a wrong title, it says : "Unable to find a match. Please refine your search", and you can modify your request easily or choose Cancel (even if it is only a "false" cancel ;)).
