Import from IMDB Favorites
deathbyaclown
Post by deathbyaclown »
I'm not sure if something like that already is existing.. I was wondering if its possible to import ones favorites from IMDB into Ant ?
Best Regards
Andreas
It depends how IMDB login works. If it uses cookies then it is not possible currently. And anyway the script cannot create new movies, it can only fill infos for a predefined list of movies.
deathbyaclown
IMDB uses cookies afaik - I was afraid of that ... but thanks
