"Save As .XML" : last fields not saved
acteo
Post by acteo »
Hello,
When i save my catalog as an XML file, the last fields don't appear in the xml file : resolution, framerate, file sizes, Disc/Files (maybe there is more).
For all movies? I don't see what could cause that in your case :??:
When you reopen the XML file with AMC, all info except these few fields are there?
acteo
Post by acteo »
i'm not at home at the moment but i made a test
it works fine, i can see fields in which i wrote something
i guess that when a field is empty, it is not saved in xml file.
At home those fields are empty...so i should be wrong... sorry
Actually i wanted to use the field 'resolution' to store the filepath of the movie and export the database to MediaPortal. Is it planed to add a field in AMC for this data ?
It is planned for a future version, but currently you can use the URL field for storing a file path.
michel
xml export
Post by michel »
interesting your comments ... cause could not find the xml export possibility !!!
am i stupid ?
found all other possibilities as sql - html - csv ... etc .. but no xml
can you help ?
thanks
michel
michel
xml ...
Post by michel »
ok - sorry for the disturbance - think i found following your "aide" with the "save as"
thought initially that there was an automatic export in the export function.
am i right ?
Some XML-based templates are made for a use with HTML export: you use a XML file rather than HTML file, but it is filled in the same way.
michel
xml
Post by michel »
can i save my collection in xml without pictures ? and how ?
thanks
M
When you save to XML it asks if you want to export pictures or not. If they are not stored in the catalog. Pictures are not stored in the XML file anyway, so if you only keep the XML file there is no picture.
michel
ok thanks
Post by michel »
ok - perfect - thanks a lot
