renumber
renumber
Hello
I got something like this:
50 Movie1
51 Movie2
52 Movie3
53 Movie4
54 Movie5
and i need to do this:
50 Movie1
51 Movie2
53 Movie3
54 Movie4
55 Movie5
How to do it ???
(sory for my english, is not my good side :))
You mean increasing by 1 the number of some movies ?
You can do it with the Scripting.
Select the movies to modify, then go to Tools -> Scripting, select "Editor" tab, click "New", and enter the following line between begin and end :
SetField(0, IntToStr(StrToInt(GetField(0), 10) + 1));
Then Run this script, it should display a message saying it executed successfully.
Close the Window, now the number should have been changed.
Try to not get duplicate numbers, or the Loan window may have problems.
ohhh yessss :) You saved me from doing all catalog from begin :)
Thank You very much. :grinking:
