Looking for a special HTML Template
deathbyaclown
Post by deathbyaclown »
Actually i like the default HTML template provided by Ant. My problem is that all the movies are displayed on one page.... so you have to scroll a lot.
I would appreciate a template where one can specify how many movies are shown on one page or that you have an alphabetical index on the top (or any where else) of page to navigate...
is there an existing template for that ?
Thanks so much
deathbyaclown
Ps: Maybe you can answer me another question concerning the export. How do you export the movies in detail ? When I select a template Ant just generates the main page. All links do not work because it cant find the detail page ? apparently it doesnt generate the $$ITEM_FILEINDIV files ?!
deathbyaclown
ok - i found Twinks Template which does exactly what I need...
sry for bothering :)
but apparently its just working with IE - dont see anything in FireFox :(
Re: Looking for a special HTML Template
deathbyaclown wrote: Ps: Maybe you can answer me another question concerning the export. How do you export the movies in detail ? When I select a template Ant just generates the main page. All links do not work because it cant find the detail page ? apparently it doesnt generate the $$ITEM_FILEINDIV files ?!
Above the HTML editor area, you have a drop-down menu that allows to select if you want to import both templates (full & individual) or only selected one.
I know, this thing is not very well designed :/
deathbyaclown
thanks for your answer.
I think the CurrentStupidUserException is thrown :-(
I have the following setting:
so the button "Full" is selected and "Export both". But still only the main page is created ?
What do I miss ?
And you have something loaded as individual template too? (i.e. when you click on "Individual" do you see the code for the individual template)
deathbyaclown
no there wasnt any template loaded ;-)
so problem is solved - thanks !!
