"Search for value"
kinetix
"Search for value"
Post by kinetix »
Is there a way to do a more "advanced search"?
What I would like to do is to look up more than one actor (within the Actor-field).
Say that I would like to look up which movies Arnold Schwarzenegger and Sven-Ole Thorsen have worked on together.
As far as I know, I can only search for either Schwarzenegger or Thorsen.
Sure, I can use IMDb's search function, but it would go faster this way.
Maybe it could be done by either a "Anywhere-Within-The-Field-Checkbox"-function or "use" "quoatation marks"-function (like Google, Altavista...)
Thoughts on this?
Currently it is not possible.
I could maybe add in the next version a "refilter" button quite easily, that could be used together with the "display results" option then.
kinetix
Post by kinetix »
Sounds great! :)
