Kudos and a question
Hey!
First of all I must say that your manager is awesome.
I used DivX Manager before, but will never again after I have discovered this one :D Talk about sucking up, eh? ;) Anyway... I have a question:
I encode movie audio using Ogg Vorbis, and then muxing audio and video with OggMux. When I then try to import the data into Ant I only get the size of the movie. It doesn't read any video/audio information. Not type, nor data. Do you have any plans to update the manager to accept Ogg media files? I will use it anyway though :cool:
Cheers!
/ELRoS
Sure, I'll add support of Ogg, MPEG, Real, Quicktime
But for that I will have to find how to do it :D
I found C++ source code to do it for MPEG and Ogg (if I remember well), I should translate that to Pascal to integrate it into the program.
