[ITA-Update] FilmUP with big pictures again and COMMENT TOO!
ABNormal
Post by ABNormal »
1) FilmUP gives Big Posters again.
2) I've studied my latest script and tried to correct it.
Now Comments should work again.
So FILMUP is fully working again (i hope)
Now My new script:
Authors=L. Francisco
Title=FilmUP
Description=Get movie info from LeoFilmUP.it
Site=http://filmup.leonardo.it
Language=IT
Version=1.0.2 - 16.09.2005
Requires=3.5.0
Comments=**Changes**|Pivello: query URL changed|Zandal:  sistemato puntamento a COMMENTS|Pivello: Film site URL selectable instead of FilmUp page URL|dinolib: adapted to v.3.5.0 and little bugfix | ABNormal restarted...|14.04.2005: Fixed infinite loop if description field missing (Pivello)|16.09.2005: Look for new Main Actors data into page; if present select this instead of Cast data (P)|16.09.2005: Added ActorPlusCast option (P)|03.10.2005 ABNormal: Big Posters and Comments again
License=*  The source code of the script can be used in   |*  another program only if full credits to              |*  script author and a link to Ant Movie Catalog  |*  website are given in the About box or in       |*  the documentation of the program               |
AlternateURL=0|0|0=Use the FilmUP web site for FieldURL|1=Try to use ufficial movie web site for FieldURL
MezzoVoto=1|1|0=Integer Ratings|1=Ratings with ,5
ActorsPlusCast=0|0|0=Get Main Actors data (if present) otherwise get Cast field|1=Get Main Actors data (if present) and Cast data
program LeonardoFilmUP;
  StringUtils1;
  TheMovieAddress: string;
  comm: String;
  LineNr: integer;
  BeginPos: integer;
  LineNr := FindLine('Ordina risultati per', Page, 0);
  if LineNr = -1 then
    AnalyzeMoviePage(Page);
    AddMoviesTitles(Page);
    if TheMovieAddress='' then
      if PickTreeExec(Address) then AnalyzePage(Address);
  Line, PreviousLine, NomeHtml, sTemp: string;
  LineNr,PrevLineNr, BeginPos, EndPos, Field: Integer;
  IsMainActors: boolean;
  IsMainActors := false;
  sTemp := '';
  LineNr := FindLine('<font face="arial, helvetica" size="3"><b>', Page, 0);
  if LineNr > -1 then
    //Translated Title
    HTMLRemoveTags(Line);
      //Look for next info
        LineNr := LineNr + 1;
      until (Line<>'')  or (LineNr > Page.Count);
      // Test if 'Trama:' missing
      if ((PreviousLine = 'Data di uscita: ')
      or  (PreviousLine = 'Uscita prevista: ')) and (Line <> 'Trama:') then
        if (copy(Line,1,6)<>'Trama:') then
          Line := 'Trama:' + Line;
      PreviousLine := Line;
      //Look for type of line
      if Line = 'Titolo originale: ' then
        Field := fieldOriginalTitle
      else if Line = 'Regia: ' then
        Field := fieldDirector
      else if Line = 'Produzione: ' then
        Field := fieldProducer
      else if Line = 'Nazione: ' then
        Field := fieldCountry
      else if Line = 'Genere: ' then
        Field := fieldCategory
      else if Line = 'Anno: ' then
        Field := fieldYear
      else if Line = 'Durata: ' then
        Field := fieldLength //Special case: get number only
      else if Line = 'Sito ufficiale: ' then
        Field := fieldURL
      else if Line = 'Attori protagonisti: ' then
        Field := fieldActors;
        IsMainActors := true;
      else if Line = 'Cast: ' then
      else if Line = 'Trama:' then
        Field := fieldDescription
        Field := 0;
      // I have to add this test, for sometimes the description
      // is on the same line as the tag 'Trama'
      if (copy(Line,1,6)='Trama:') and (length(Line)>6) then
        Field := fieldDescription;
        Delete(Line,1,6);
        HTMLDecode(Line);
        //Get values
        HTMLDecode(Line);
        //Special case: Length
        if Field = fieldLength then Line := copy(Line,1,length(Line)-1);
       //Alternative URL case
       if (field = fieldURL) then
         if (Length(Line) = 0) or (GetOption('AlternateURL')=0) then      // if WEB url missing or explicitly requested...
           Line := GetField(fieldURL)  // ...restore FilmUp URL
           Line := 'http://'+Line;
      if Field<>0 then
       if Field = fieldActors then
         if IsMainActors then // Remember Main Actors (if present)
           sTemp := Line;
           if ((GetOption('ActorsPlusCast')=1) and (sTemp<>'')) then
             Line := sTemp + ' Cast: ' + Line
             if sTemp <> '' then
               Line := sTemp;
           SetField(Field,Line);
    until (Field=fieldDescription) or (LineNr > Page.Count);
  PrevLineNr := LineNr;
  //Comments
  LineNr := FindLine('">Recensione</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('Scheda', Line) <> 0 then Delete(Line,1,pos('Scheda',Line));
    if Pos('DVD', Line) <> 0 then Delete(Line,1,pos('DVD',Line));
    Delete(Line,1,pos('href="',Line)+5);
    NomeHtml :=Copy(Line,1,pos('"',Line)-1);
    if (copy(NomeHtml,1,1)<>'/') then
      NomeHtml := '/' + NomeHtml;
comm := textbetween(GetPage(NomeHtml),'<font face="arial,helvetica" size="2"><b>','<a class="filmup" href="opinioni.htm">');
comm := textafter(comm,'</b><br>'+#13#10);
HTMLRemoveTags(comm);
SetField(fieldComments,comm);
  //Rating
  LineNr := FindLine('">Opinioni</a>', Page, PrevLineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('Recensione',Line));
    Line := GetLineFromOtherPage(Copy(Line,1,pos('"',Line)-1),'</b> - <img src="');
    if Line <> '' then
      Line := Copy(Line,1,pos('</b> - <img src="',Line)-1);
      if GetOption('MezzoVoto')=0 then
 if pos('.',Line)>0 then Line := Copy(Line,1,pos('.',Line)-1);
      SetField(fieldRating,Line);
  //Picture
    LineNr := FindLine('<img src="locand', Page, PrevLineNr);
    if LineNr > -1 then
      Delete(Line,1,pos('<img src="locand', Line)+9);
      GetPicture('http://filmup.leonardo.it/'+Copy(Line,1,pos('"',Line)-1));
  LineNr := FindLine('href="posters/locp/', Page, PrevLineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('href="posters/locp/',Line)+5);
    Line := GetLineFromOtherPage('http://filmup.leonardo.it/'+Copy(Line,1,pos('"',Line)-1),'<img src="../loc/500/');
    if Line <> '' then
      Delete(Line,1,pos('<img src="../',Line)+12);
      GetPicture('http://filmup.leonardo.it/posters/'+Copy(Line,1,pos('"',Line)-1));
  //DisplayResults;
function GetLineFromOtherPage(address: string; hint: string): string;
  LineNr: integer;
  LineNr := FindLine(hint, Page, 0);
  if LineNr > -1 then result := Page.GetString(LineNr);
procedure GetComments(address: string);
  BeginLine: integer;
  EndLine: integer;
  i: integer;
  Line, Comments: string;
  BeginLine := FindLine('RECENSIONI', Page, 0);
  BeginLine := FindLine('<font face="arial,helvetica" size="2"><b>', Page, BeginLine);
  EndLine := FindLine('<a href="opinioni.htm">Scrivi la tua recensione!</a></font><br><br>', Page, BeginLine);
  for i:= BeginLine+1 to EndLine-1 do
    Line := Page.GetString(i);
    Line := StringReplace(Line, '<br>', #13#10);
    Line := StringReplace(Line, #13#10#32, #13#10);
    HTMLDecode(Line);
    Comments := Comments + Line;
  BeginPos, EndPos: Integer;
  LineNr := 0;
  LineNr := FindLine('FilmUP - Scheda: ',Page,LineNr);
while LineNr > -1 do
  MovieAddress := 'http://filmup.leonardo.it/sc_' + TextBetween((Page.GetString(LineNr-1)), '_', '.') + '.htm';
  MovieTitle := TextAfter(Page.GetString(LineNr), 'Scheda: ');
      While pos ('<span', MovieTitle) > 0 Do begin
      MovieTitle := TextBefore(MovieTitle, '<span', '') + TextAfter(MovieTitle, 'bold;">');
      While pos ('</span', MovieTitle) > 0 Do begin
      MovieTitle := TextBefore(MovieTitle, '</span', '') + TextAfter(MovieTitle, '/span>');
    HTMLRemoveTags(MovieTitle);
    HTMLDecode(Movietitle);
    LineNr := FindLine('FilmUP - Scheda:',Page,LineNr+1);
    if TheMovieAddress='*' then
      TheMovieAddress := MovieAddress
      TheMovieAddress := '';
  LineNr := FindLine('Successivo',Page,LineNr);
  BeginPos := pos('HREF',Line);
  if BeginPos>0 then
    Delete(Line,1,BeginPos + 5);
    EndPos := pos('"',Line);
    MovieAddress := copy(Line,1,EndPos-1);
    PickTreeMoreLink(MovieAddress);
// Questo è il main dello script
  if CheckVersion(3,5,0) then
    TheMovieAddress := '*';
    MovieName := StringReplace(GetField(fieldTranslatedTitle), '.', ' ');
While pos ('[', MovieName) > 0 Do begin
  MovieName := TextBefore(MovieName, '[', '') + TextAfter(MovieName, ']');
    if Input('FilmUP Import', 'Digita il titolo del film:', MovieName) then
      AnalyzePage('http://filmup.leonardo.it/cgi-bin/search.cgi?q='+UrlEncode(MovieName)+'&ul=%25%2Fsc_%25');
    ShowMessage('Questo script richiede una versione più nuova di Ant Movie Catalog (almeno la versione 3.5.0)');
bye
ABN
I post here to make the topic go up, above the old one :D
claustro
Post by claustro »
I receive this message in the comments space.
The link is correct if you add the missing letters in the title?
Nello spazio dei commenti mi viene sempre questo messaggio il link è giusto se si aggiungono le 2 lettere mancanti nel titolo
Il commento lo trovi su: http://filmup.leonardo.it/thdaygirl.htm
E' un problema solo mio
Grazie
