one question
darts501
one question
Post by darts501 »
i have amc music catalalog near 1000 cds is posible import all data base
from internet using scripts??
thank you
If you have a script for it, yes. I guess that some scripts for music are available from Mods section of the forum.
darts501
i know scripts in mods
Post by darts501 »
but the question is , those scripts goes one by one , and my question is is posible make it all together??
What do you mean?
DRAG@N
Post by DRAG@N »
Hi darts501,
A script for Gracenote already exists (as you asked here)
You can find this script in the Mods section : [REL] Gracenote, FreeDB, Amazon (for information : Gracenote = CDDB)
After downloading it (don't forget the "Amazon support" file), you will be able to import all data you need from internet, just like this :
F6 > choose CDDB script > in "Script limitations", check "All" > then "Run".
But, it's true, the script always ask a confirmation for the CD title, because there is no batch mode for this script yet, but you can edit it yourself or ask somebody on the concerned forum to make this option. Or maybe find another one which is supporting batch mode.
