The only thing that REALLY must be done...
barmagloth
Post by barmagloth »
...is automatical resize of pictures when storing into catalog AND exporting to a web page. E.g. 800x800 max for local storage and 200x200 max for a web page. There are PLENTY of open sources that can provide you with code needed - GIMP sources for example (written in C++ I suppose).
The GIMP source would be useless for that (not so easy to take a part of another program... especially if it is written in another language :p)
There are librairies for doing a resize in Delphi.
This is on my todo list, like lots of other things...
