order from DVD ?
LucMa
order from DVD ?
Post by LucMa »
HI:)
Is possible oder the movie in this mode
DVD 1
Title 1
Title 2
DVD 2
Title 1
Title 2
For me now is hard find where is the movie that i m looking for:(
Thank's
Depends on how you added your dvd in the list. If the DVD number is in the media field (what I do myself), you can use tools => Group by => media label
LucMa
Post by LucMa »
My DVD are named
Movie 01
Movie 02
a dvd content about 5 movie
your thicks don't work for me:(
I put in Media Label the number of first movie of the disc, for all the movies that are on this disc. So when I group by Media Label it puts together the movies that are on the same disc.
LucMa
Post by LucMa »
I can't re-masterize all my dvd:)
:??: You do not have to modify your DVD, simply put this info in the catalog itself
LucMa
Post by LucMa »
Sorry my english is terrible, can u tell me exactly what i must do?
Step by step please :)
LucMa
Post by LucMa »
u mean that i must change manually all the numer of my movie like the number of the media? For 500 movie is to hard for me:)
LucMa
Post by LucMa »
ok, if is the only way i start the change of number but i have other two question
1) What i must do for sort the list ordered by numer?
2) How can i change the name of the database sort by Media? Now is named < none > (192)
Thank's for your help:)
The sort by number or title is changed by clicking column headers.
Number    Media
 1             1
 2             1
 3             1
 4             1
 5             1
 6             6
 7             6
 8             6
 9             6
 10            6
 11           11
 12           11
etc.
To prevent the "none" group to appear, there is an option somewhere that prevents this
There is also an option to sort the media like if it was a number, so the grouped movies will be integrated to the list.
e.g. :
movies 806 & 808 are alone on a DVD, the others are at 5 or 6 on a DVD
LucMa
Post by LucMa »
Many thank's, i see if i can do it without problem:)
