Some suggestions (mainly for multilingual use)
Bad Joker
Post by Bad Joker »
hi antoine
after working quite a lot with your program, i have some major issues for your next versions to make this programm easier for multilingual use
1)
add a function to replace entrys inside the movies for folowing fields:
-country
-category
-video format
-audio format
-language
-subtitle
this functions is very useful when you want to translate values from the imdb import (example: replace "UK" with the entry "England")
2)
add a function to configure, which boxes should always be checked/unchecked to import values from a script
for me as a divx user of this program, i never import the language and the lenght of a movie from imdb, but i always are forced to uncheck this boxes...
3)
can you change the imdb script the way, that you can import the alternativ titles (i always use the german one, if there is one, but i have to look it up manually)?
thats all atm i can imagine, your program just rocks and i love it... best movie liste EVA :grinking:
Hi.
1. I plan to add something for these, but I do not know already how.
2. I'll probably add that
3. I'll try to add the possibility to select the alternative title from a list of all alternative titles found.
Bad Joker
Post by Bad Joker »
fine :grinking:
