Scripts that need to be fixed / Scripts à corriger
I'll make here a list of the scripts that have been reported as not working anymore.
If you want to contribute to the program and that you have some Pascal/Delphi programming knowledge, you can try to repair or rewrite one of these scripts. In this case, please post only a link to the repaired file, or create a new topic to post the script.
You can also report here the scripts that do not work.
Je vais établir ici une liste des scripts pour lesquels on m'a signalé un problème de fonctionnement.
Si vous voulez contribuer au programme et que vous avez quelques connaissances de programmation en Pascal/Delphi, vous pouvez tenter de réparer ou réécrire un de ces scripts. Dans ce cas, merci de ne poster qu'un lien vers le fichier, ou créez un nouveau sujet pour y poster le script.
Vous pouvez également rapporter ici les scripts qui ne fonctionnent pas.
cricounette
Post by cricounette »
celui-là ne marche pas non plus
http://www.cinestore.com/
Il a été corrigé récemment : http://www.antp.be/temp/scripts/Cin%e9store.ifs
cricounette
ok rectification faite
merci :grinking:
molgar
Post by molgar »
http://www.antp.be/temp/scripts/FilmAffinity%20(ES).ifs doesn't download the images anymore.
There was a newer version on this topic, but it seems to have the same problem actually. Maybe it would be useful to also report the problem there ;)
kreti
Post by kreti »
Problem with pictures in filmaffinity fixed here viewtopic.php?t=2398
Alain2
Post by Alain2 »
cinemovies.fr has just updated its website, and ScorEpioN script is not working with it anymore...
it would be useful to also post the info in his topic ;)
cobrajet
Post by cobrajet »
OfBD.de does not work anymore.
you can choose the right movie when the window splashes up. but the information is not taken from the site.
I guess ofbd changed the layout
pinterpeti
Post by pinterpeti »
[HU]netpiac.hu.ifs (http://www.netpiac.hu) doesn't work either it says: HTTP/1.0 500 Internal Server Error
skyalex
Post by skyalex »
The script cinefacts.de does not import the bonus materials of a DVD even if there are infos on the web page.
IN Movie Ant only the header "Bonusmaterialien" appears, but nothing below.
IMP Awards script is not working.
robgarib
Post by robgarib »
AF digitale (IT) script ask for a registration
coona
csfd.cz script doesn´t work :(
Post by coona »
csfd.cz.ifs doesn´t work - http/1.0 403 Forbidden :(. Can anyone fix it please. BIG thanx in advance
Incubus
tv.com
Post by Incubus »
the tv.com script,
i am unable to get results using this script, i may get the series name, but then it wont grab the epname, any ideas, maybe the paramatesrs are too tight, i dunno, if you get a chance please look into this
robochief
Post by robochief »
Guest wrote:IMP Awards script is not working.
I'd like to see a fix too.
Marbles_00
Post by Marbles_00 »
Has anyone been able to fix the script for www.dvdempire.com ? Great site for getting covers. I thought they added UserID tags, but it made no difference when adding them to the script (granted I did it right as I'm no where close to being a script writer).
Thanks in advance.
David
bigstoyan
Post by bigstoyan »
Is there anyone who uses the IMDB script? :) I think so... This great script is not working correctly for 1 or 2 months, and I want to ask - can anyone know why? And if anypne can help and fix it Ill be very thankful!
