Question about images
Teebee
Post by Teebee »
Is it possible to show the images in the actual size they are, unless they are bigger then the given space ?
The images get shrinked when they are bigger then the space that is given, but is it also possible that when the images are smaller that they are also been show at real size ?
That way i can see wether some images need te be replaced by bigger ones.
Its a big list > 1000 so it is real time consuming if I have to click on each and everyone, without exporting them, checking their numbers, or writing it down .
If you disable the "fit picture in window" option, the pictures will be displayed at real size
Teebee
Post by Teebee »
I feel stupid.
I looked at the preferences for like 10 minutes and i didnt see that one, guess i'm in need of some vacation :hihi:
Teebee
Post by Teebee »
Question about images again. Is it possible to export the image dimensions, eg. 150x200 to see which sizes the images have so i can locate the small ones in the catalog (+1500 titles)
You can export all images and then use XnView or another image-viewing program to sort the images by size (or maybe do this sort directly in XP explorer)
