fetching data + images
Teebee
Post by Teebee »
I was wondering if it is/would be possible when i add a new movie get the data of imdb, afterwards i want to grab new dat from eg. moviemeter.nl that, when the image is smaller then the one i allready have, it doesnt get the new one, but when it is bigger, it gets the bigger one.
Now i can enable/disable the picture selectbox, but that way i either get the new ones, even if they are smaller, or i get none at all.
So, in short, if new picture is bigger then the old one, fetch it. If it is smaller, skip the new picture.
I could add options for that: In the summary window displayed after the data import, the sizes of old & new pictures are displayed, but I could make the choice automatic...
Teebee
Post by Teebee »
I think it would be better to have an option, so people can choose if they want to update it. Perhabs they prefer smaller images, or their own custom ones.
Yes, as I said I could add option for that. But in my previous post the ":" should have been a "." to make it logical :D
Teebee
Post by Teebee »
Would it also be possible to show the images aswell, so you can choose which one you like best?
You can click on the area where the size is displayed to see the image
