Solution for connection errors using IMDB script in batch
seehowyouare
Post by seehowyouare »
Hi all,
Ant Movie Catalog is a great program and the scripts are great. Thank you :grinking:
I had a problem when using IMDB script in batch mode. I would often get socket error and Not Found errors when retrieving information from IMDB.
The problem was my Avast anti virus program.
I temporarily disable the Avast scanner and now my batch runs fine.
Hope that helps someone.
