Time & Date
pah96
Time & Date
Post by pah96 »
Hello!
I'm using AMC for more then 10 years and it is really great! I hope this will be going on for a long time.
Only 2 following small features for the future would be nice:
1) possibility to COPY/PASTE text in the search field with mouse
2) in the status line (or where ever) information about the current time (and date)
BR,
pah96
Re: Time & Date
Indeed the context menu for the search was already requested. As I don't really work on the program any more (except maintenance, to keep it running) there is little chance that I add that at some point, unfortunately. But maybe some day, who knows...
Copy/paste can still be done with Ctrl+C/Ctrl+V or Ctrl+Ins/Shift+Ins.
About the status, there is the current date & time in Windows taskbar, I don't see why putting it in the program :??:
pah96
Re: Time & Date
Post by pah96 »
Hello!
Yes, the system context menue for the search bar would be really great!
ad "time&date": for those how are hiding the taskbar to use the AMC in fullscreen ;)
br,
pah96
