Quick print
Quick print
Hi Antoine, I suggest the quick print feature: print using the last used printing template with or without the printer driver window (M$ Word have something like this). In this way the informations needed can be printed very quick.
It should at least remember the last template when opening the window, that will be added. I could make the "print" button of the bottom of the window print without confirmation, and keep the "print" icon of the print window's toolbar work as it does currently.
I'm not sure I understand what you say, but a simple check button with "remember the last template used" will be fine for now. Maybe in the future the quick print will be implemented.
Actually I could remember the last used template in all cases. I do not know why I haven't done it since for HTML Export and for scripting the last used file is already kept.
