Checkout Grouped Movies
WhACKO
Post by WhACKO »
I'd like to be able to check out movies grouped by Media Label instance (as shown on the main screen with grouping turned on), e.g. I have dvd's with 6-7 movies on them and when I check the dvd out, to be shown like a group (just the Media Label title, or with a [+] in front) and not all of the movies on the dvd, cause it clogs up the display, and it would be a slight improvement IMHO
You mean that you'd like to have the grouping applied to the Loans window too?
I could probably add that easily once I'll replace the list/tree by another one and that I make this a little cleaner.
WhACKO
Post by WhACKO »
Thank You for saying it so simple :) That's Exactly what I meant/wish for. Just keep up the good work!
