[req] Script to copy movie info from another database (amc)
LA
Post by LA »
please write a script, which will search a movie within another amc database (should be chosen) and then will extract info from this database to current...
or please let me know the format of amc database.
thanks
It is not possible to make that by script.
It could maybe be done with a .xml database rather a .amc database.
The format of the .amc files is described in the help file.
What do you want to do exactly ? If you want to merge two database you can simply use the Import window.
LA
Post by LA »
why it is not possible? if we can read files and we know the format of the file, seems that we can do it.
I want to copy info on one/two/three movie(s) from one database to another.. not to merge databases!
I do not think that the script engine can handle binary files, but actually I never tried. One of the problem is that you'll have to read strings from the file like if it was a simple memory area, for that you need to force the length of the string and then have a pointer to its first character. And these two things cannot be done with the script engine. But maybe it can be done in another way.
LA
Post by LA »
I have asked the same question to developers of Pascal Script. And the ff answer was received:
You can use the streams part of the classes import library to read from a file.
Do you know what does it mean? ;) I need just a idea, how to read binary files...
That does not solve the other problem, i.e. the access to string memory. Maybe that in IFPS3 more things are possible, but AMC still uses IFPS2.
LA
Post by LA »
but I have written small script, which allow to copy info from another database in xml format (the script will be sent via e-mail).
Could you please let me know how I should verify if some property exists (or doesn't exist)?
for ex., if I have the ff code:
SetField(fieldSize,CurItem.GetItemNamed('Size').Value);
but this item doesn't include item named 'size'. I am getting the error. How it can be avoided?
if CurItem.GetItemNamed('Size') <> nil then
(I think)
LA
Post by LA »
yes, it works. thank a lot.
but how I should add picture into catalog, if I now the path to the picture?
LA
Post by LA »
sorry, corrected previous msg:
yes, it works. thanks a lot.
but how I should add a picture into catalog, if I know the path to the picture?
It is not possible to do that unfortunately.
The GetPicture function can only import picture from http URL.
I really have to add functions to manage pictures.
