Unable to run "report designer"
darth
Post by darth »
I am a total newbie to the Ant Movie Catalog program. I downloaded and installed it just today.
In fact, I have installed it on 2 machines in an effort to see if the problem I have was machine specific but alas it is not.
The catalog prog. itself looks just great... however I am unable to run the 'report designer' that came with the program and a search of the forum gave me nothing specifically (that I could find) about this.
When I start report designer something flashes on my screen but it is so fast tht I cannot read it... and report designer simply does not appear.
Anyone have this too ?? and if so, any ideas on what to do to fix it.. Machine is a P4 with XP Pro & all available updates instaled.
That's strange... If you try to run it from the Start menu, or by launching AMCReport.exe, does it work?
darth
Post by darth »
:grinking: thankyou 'antp' for your reply. Without me doing anything it has suddenly decided to work. Thats computers for you....
