Grabbing a second picture
KaptK
Post by KaptK »
Could you add a function to the scripting to allow the grabbing of a second picture.
I was using the DVDEmpire script and have come from Movie Collector where their DVDEmp script, imports the front and back cover of a movie.
cheers,
Kaptk
The program cannot handle more than one picture per movie in the current version.
It is planned for a future version.
KaptK
Post by KaptK »
Thanks,
I don't even need the program to show the picture internally. I just want to be able to download a second picture at the moment along with the first one.
I'm wanting to use it in a template I was going to make.
I'll keep a look out for a new version that does this but I think I may have to keep using what I am until it does this.
Keep up the great work on AMC!!
KaptK
Post by KaptK »
I think I can make this work in the meantime by outputting an HTML file with links to the second pages then using a website download tool to grab the missing images.
When I get it all done, I'll post the template in the Template section.
