How To Repair My Broken Saved File?
WizzleWaxX
Post by WizzleWaxX »
Hello.
When is was improve my database in AntMovieCatalog. Everything works fine. But till i saved. When i want to save it my computer restarts. While AntMovieCatalog was saving.
When the computer restarts I want to reopen my Databse in AntMovieCatalog but get an error!
Is there anthing i can do to get my databse back?
In my database are 800+ movies yet. And don't have sense to make it new. So can anybody help me?
Grtz WizzleWaxX
WizzleWaxX
Sorry. Link above doesn't work.
Hope this is a better link.
If this link still don't work. here is the explenation of the error box:
Unable to load file "E:\Program Files\Ant Movie Catalo\###Speelfilms\benjy_goed.amc": Cannot identify file type from header
The link does not work because it is a BMP image rather than a PNG, GIF or JPEG I guess.
Well, for your problem, what size is the file? If it is only few KB where it was several MB before, then the file is lost.
If it is still quite big then I guess it became corrupt, but I do not know what could produce that :/
WizzleWaxX
No the file is still almost 9 MB. Is there anything you can do than?
Sorry for my bad english. Hope you understand it :D
On the topic bellow yours some other people had the same problem:
viewtopic.php?t=1867
Can you also open the file with notepad and post the beginning of the file ?
WizzleWaxX
antp wrote:On the topic bellow yours some other people had the same problem:
When i open the amc file in notepad. Everything is blank. Nothing in it. So can't post the beginning of the file!
WizzleWaxX
Also opening the BAK giving no explenation. is it hopeless now :P
WizzleWaxX
Yeah it works again!
I'ved open the BAK file in AMC. all the files are in yet. Only the pictures are not there but that is simply to make new.
Then saved it to an AMC file en can open the file now!
Thx for your help
