"|" char and amc->xml->amc
iradic
Post by iradic »
hi
i found that '|' char is used as 'new-line' in xml catalog ... and that conversion amc -> xml -> amc catalog is not good if for example your comment text contains this character...
sorry if this has been already discussed...
bye
I thought that it the probability that "|" is used in a field was quite low... ;)
hi
you're probably right in most cases ... in my case i often put media file info ... ex. from mkvinfo.exe or besweet output ... and they contain a lot of '|' ...
hope you will find a solution for this
bye
In a future version I'll use CDATA nodes, at least for the fields that may contain linebreaks ;)
