[REL] [ES] Caratulasdecine Update
japg2000
Post by japg2000 »
I've solved some problems with the script
Authors=japg2000 (japg2000@terra.es)
Title=CaratulasDeCine
Description=Picture importation script for www.caratulasdecine.com
Site=www.caratulasdecine.com
Language=ES
Version=1.2
Requires=3.5.0
Comments=
program CaratulasdecineImport;
  Title: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  result := S;
  while Pos(CR, result) = 1 do
function CadenaEntre(var S: string; StartTag: string; EndTag: string): string;
  InicioPos: Integer;
  InicioPos := Pos(StartTag, S);
  Delete(S, 1, InicioPos + Length(StartTag) - 1);
  InicioPos := Pos(EndTag, S);
  result := copy(S, 1, InicioPos - 1);
  Delete(S, 1, InicioPos + 1);
function PreparaTitulo(T: string): string;
  result := AnsiLowerCase(T);
  HTMLDecode(result);
  result := StringReplace(result, chr(146), '');
  result := StringReplace(result, chr(39), '');
  result := StringReplace(result, '´', '');
  result := StringReplace(result, '`', '');
  result := StringReplace(result, '"', '');
  result := StringReplace(result, '¿', '');
  result := StringReplace(result, '?', '');
  result := StringReplace(result, '¡', '');
  result := StringReplace(result, '!', '');
  result := StringReplace(result, '.', '');
  result := StringReplace(result, ',', '');
  result := StringReplace(result, ':', '');
  result := StringReplace(result, ';', '');
  result := StringReplace(result, '-', '');
  result := StringReplace(result, '/', '');
  result := StringReplace(result, '\', '');
  result := StringReplace(result, '_', '');
  result := StringReplace(result, 'á', 'a');
  result := StringReplace(result, 'é', 'e');
  result := StringReplace(result, 'í', 'i');
  result := StringReplace(result, 'ó', 'o');
  result := StringReplace(result, 'ú', 'u');
  result := StringReplace(result, 'ä', 'a');
  result := StringReplace(result, 'ë', 'e');
  result := StringReplace(result, 'ï', 'i');
  result := StringReplace(result, 'ö', 'o');
  result := StringReplace(result, 'ü', 'u');
  result := StringReplace(result, 'ñ', 'n');
function GetCaratulasDeCineDir(MovieTitle: string): string;
  PageOfLetter: Array of string;
  C: Char;
  Index: Integer;
  Setarraylength(PageOfLetter,36);
  PageOfLetter[0]:='0_9';  PageOfLetter[1]:='0_9';  PageOfLetter[2]:='0_9';  PageOfLetter[3]:='0_9';
  PageOfLetter[4]:='0_9';  PageOfLetter[5]:='0_9';  PageOfLetter[6]:='0_9';  PageOfLetter[7]:='0_9';
  PageOfLetter[8]:='0_9';  PageOfLetter[9]:='0_9';  PageOfLetter[10]:='a';   PageOfLetter[11]:='b';
  PageOfLetter[12]:='c';   PageOfLetter[13]:='d';   PageOfLetter[14]:='e';   PageOfLetter[15]:='f_h';
  PageOfLetter[16]:='f_h'; PageOfLetter[17]:='f_h'; PageOfLetter[18]:='i_k'; PageOfLetter[19]:='i_k';
  PageOfLetter[20]:='i_k'; PageOfLetter[21]:='l';   PageOfLetter[22]:='m_n'; PageOfLetter[23]:='m_n';
  PageOfLetter[24]:='o_q'; PageOfLetter[25]:='o_q'; PageOfLetter[26]:='o_q'; PageOfLetter[27]:='r_s';
  PageOfLetter[28]:='r_s'; PageOfLetter[29]:='t_z'; PageOfLetter[30]:='t_z'; PageOfLetter[31]:='t_z';
  PageOfLetter[32]:='t_z'; PageOfLetter[33]:='t_z'; PageOfLetter[34]:='t_z'; PageOfLetter[35]:='t_z';
  C := copy(MovieTitle, 1, 1);
  if (C >= '0') and (C <= '9') then
  	Index := Ord(C) - Ord('0');
  	Index := 10 + Ord(C) - Ord('a');
  result:='http://www.caratulasdecine.com/' + PageOfLetter[Index] + '.htm';
procedure AnalyzePageCaratulasDeCine(PageDir: string);
  CaratulasdecinePage, MoviePage: TStringList;
  MovieDir, Line, LineTmp: string;
  Encontrado, Salir, BeginPos, EndPos, LineNr, LineMov: Integer;
  CaratulasdecinePage := TStringList.Create;
  CaratulasdecinePage.Text := GetPage(PageDir);
  LineNr := FindLine('</big></big></big></big></big></big>', CaratulasdecinePage, 0);
  LineNr := LineNr + 1;
  Line := CaratulasdecinePage.GetString(LineNr);
  Line := EliminaInicio(Line, ' ');
  Salir := 0;
  Encontrado := 0;
    while (Pos('<br>', Line) = 0) and (Pos('</td>', Line) = 0) and (LineNr < 10000) do
      if copy(Line, Length(Line), 1) <> ' ' then
        Line := Line + ' ';
      LineTmp := CaratulasdecinePage.GetString(LineNr);
      LineTmp := EliminaInicio(LineTmp, ' ');
      Line := Line + LineTmp;
    if Pos('</td>', Line) > 0 then
      Salir := 1;
    if Pos('<a class="A" href="', Line) > 0 then
      MovieDir := 'http://www.caratulasdecine.com/' + CadenaEntre(Line, '<a class="A" href="', '">');
      MovieDir := Line;
      MovieDir := CadenaEntre(MovieDir, '<a href="', 'class="A">');
      while Pos('<a href="', MovieDir) > 0 do
    Line := CadenaEntre(Line, '', '<');
    Line := PreparaTitulo(Line);
    if Pos(Title, Line) > 0 then
      MoviePage := TStringList.Create;
      MoviePage.Text := GetPage(MovieDir);
      LineMov := FindLine('<p align="center"><img src="', MoviePage, 0);
      Line := MoviePage.GetString(LineMov);
      Line := CadenaEntre(Line, '<p align="center"><img src="', '" ');
      Line := EliminaInicio(Line, '../');
      GetPicture('http://www.caratulasdecine.com/' + Line);
      Salir := 1;
      Encontrado := 1;
    if LineNr > 10000 then
      Salir := 1;
  until Salir = 1;
  if (Encontrado <> 1) then
     ShowMessage('Titulo ' + Title + ' no encontrado en ' + PageDir)
  if CheckVersion(3,5,0) then
    Title := GetField(fieldTranslatedTitle);
    if Title = '' then Title := GetField(fieldOriginalTitle);
    Title := PreparaTitulo(Title);
    Input('Importar de caratulasdecine.com', 'Por favor, introduce el titulo:', Title);
    AnalyzePageCaratulasDeCine(GetCaratulasDeCineDir(Title));
    ShowMessage('Este script necesita una versión superior de Ant Movie Catalog (al menos la version 3.5.0)');
Greetings
japg2000
Post by japg2000 »
New version with a little change.
Now, when there are more than one movie with the same title, allow to select between them with a PickTree.
Language=ES
Version=1.3
Requires=3.5.0
Comments=
  Title: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  result := S;
  InicioPos: Integer;
  HTMLDecode(result);
  C: Char;
  Index: Integer;
  MovieDir, Line, LineTmp, TitleWeb, PageWeb: string;
  Salir := 0;
  Encontrado := 0;
  PickTreeAdd('Resultados de la búsqueda para "' + Title + '" (www.caratulasdecine.com):', '');
        Line := Line + ' ';
      Salir := 1;
      MovieDir := Line;
    TitleWeb := CadenaEntre(Line, '', '<');
    Line := PreparaTitulo(TitleWeb);
      PageWeb := 'http://www.caratulasdecine.com/' + Line;
      PickTreeAdd(TitleWeb, PageWeb);
      Encontrado := Encontrado + 1;
      Salir := 1;
  until Salir = 1;
  CaratulasdecinePage.Free;
  MoviePage.Free;
  if (Encontrado > 1) then begin
    if PickTreeExec(PageWeb) then
       GetPicture(PageWeb);
  end else if (Encontrado = 1) then begin
Greetings :)
Thanks again
japg2000
Post by japg2000 »
And another update, now due to a change in the structure of the page so the old versions are not working anymore.
Language=ES
Version=1.5
Requires=3.5.0
Comments=
  Title: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  result := S;
  InicioPos: Integer;
  HTMLDecode(result);
  C: Char;
  Index: Integer;
  PageOfLetter[0]:='0';  PageOfLetter[1]:='1';  PageOfLetter[2]:='2';  PageOfLetter[3]:='3';
  PageOfLetter[4]:='4';  PageOfLetter[5]:='5';  PageOfLetter[6]:='6';  PageOfLetter[7]:='7';
  PageOfLetter[8]:='8';  PageOfLetter[9]:='9';  PageOfLetter[10]:='a'; PageOfLetter[11]:='b';
  PageOfLetter[12]:='c'; PageOfLetter[13]:='d'; PageOfLetter[14]:='e'; PageOfLetter[15]:='f';
  PageOfLetter[16]:='g'; PageOfLetter[17]:='h'; PageOfLetter[18]:='i'; PageOfLetter[19]:='j';
  PageOfLetter[20]:='k'; PageOfLetter[21]:='l'; PageOfLetter[22]:='m'; PageOfLetter[23]:='n';
  PageOfLetter[24]:='o'; PageOfLetter[25]:='p'; PageOfLetter[26]:='q'; PageOfLetter[27]:='r';
  PageOfLetter[28]:='s'; PageOfLetter[29]:='t'; PageOfLetter[30]:='u'; PageOfLetter[31]:='v';
  PageOfLetter[32]:='w'; PageOfLetter[33]:='x'; PageOfLetter[34]:='y'; PageOfLetter[35]:='z';
  result:='http://www.caratulasdecine.com/listado.php?inicial=' + PageOfLetter[Index];
  LineNr := LineNr + 2;
  Salir := 0;
  Encontrado := 0;
      Line := Line + ' ';
      LineTmp := PreparaTitulo(TitleWeb);
      if Pos(Title, LineTmp) > 0 then
        PageWeb := MovieDir;
      MovieDir := '';
      Salir := 1;
  until Salir = 1;
     if PickTreeExec(PageWeb) then begin
        MoviePage.Text := GetPage(PageWeb);
        LineTmp := MoviePage.GetString(LineMov);
        LineTmp := CadenaEntre(LineTmp, '<p align="center"><img src="', '" ');
        LineTmp := EliminaInicio(LineTmp, '../');
        PageWeb := 'http://www.caratulasdecine.com/' + LineTmp;
        MoviePage.Free;
     MoviePage.Free;
    if Input('Importar de caratulasdecine.com', 'Por favor, introduce el titulo:', Title) then begin
Greetings
icecubix
Post by icecubix »
Thanks, japg2000. Good job
