some motion
slart
some motion
Post by slart »
can you to do next:
1) check what to show:
medialabel, source, borrower, e.t.c.
2) correct rotation text in designer:
text:
"first string
second string
third string ..."
when rotation=270:
"third string ...
second string
first string"
3) saving image inside base
slart
The second version:)
Post by slart »
Offers:
1) A choice of what to show on the main form: a genre, the director, a label, video a format, the sanction, etc.
Non-withdrawn to show in a separate window by inquiry
2) To add an opportunity to keep figures directly in base or even to import with this opportunity
bugs:
1) Wrong display of the text in cover designer, when turn =270.
So for example the text:
" The first line
The second line
The third line
It is transformed to the text:
The third line
The second line
The first line
Selecting what fields have to be displayed would also mean selecting the position of remaining fields. And that's not so easy to do :/
What do you mean by "keep figures directly in base"?
For the 270° bug, I'll put it on my list, I'll have to take some time to correct that in addition of making 180° work.
slart
Post by slart »
1) Can be, then it is simple all technical and some other information to take out in the separate form? And already, what to consider technical - on your opinion. I think it necessary to make "to unload" the main form
2) Figures = a picture:) (PROMT has translated clumsily:)) Storage of figures in base (import figures) is necessary for convenience of carry of base.
1) I planned to add an option to separate info on tabs when I'll add fields in a future version, since anyway on a 800x600 screen it will be needed.
2) it depends how you instert pictures, but by default with ".amc" files it stores pictures in the catalog file.
slart
Post by slart »
At me to default it was for some reason saved in XML therefore and there was such question.
