Hi, first of all congratulations for the program....it's the best I've ever seen.
I have a question (I tried to search in the forum but i didn't find the right topic): I wrote a language which I'd like to delete...how can i do it?
(I hope i was clear in my request).
Tnx in advance
How to modify a language
You mean in the drop-down list?
I guess that "auto-add" option is enabled and then any new value for this field is added to the list. Go to Tools -> Prefs -> Drop-down lists, and select "Languages". You can also enable the option "use values of current catalog" so it uses values already used in the field by other movies rather than using a predefined list.
