Suggestions for new versions
catwoman45
Post by catwoman45 »
1st of all - a BIG THANKS :grinking: , this is a great program, it is easy to use, handles most of the information that I need for movies and it's free :D . I recommend it to anyone who asks how I keep my collection in order.
A few suggestions for future versions:
1. Ability to create your own fields (or to change existing field names)
2. A "New/Used" field
3. The ability to separate out for/or notate box set, for box sets such as the Indiana Jones movies, or the Star Wars Box sets.
4. Some way to annotate episodes of TV Series
Again thanks for the great program, keep up the great work.
Thanks.
1. you can edit the translation file. I'll probably add several fields in a future version, and maybe one or two "custom" ones.
2. see (1) or use the checkbox in front of name, or any existing field
3. using the "group by" function if you put the name of the box in a field it would be possible, but then again it will be probably improved in the future
4. I hope to add support for that, but it would probably require some heavy changes :(
