socket error 10022
scorpion7552
socket error 10022
Post by scorpion7552 »
Hi Antoine,
there's something very strange: when I add a film using 'add from file' then 'add from internet', I get the message 'socket error 10022 invalid argument' :??:
If I don't use 'add from file' then I can add all the movies I want. What do you think of that? Am I the only one?
Information
MovieCatalog.exe : version 3.5.0.1 (créé le 21/05/2005 11:34:04)
AMCExchange.dll : version 1.0.1.6 (créé le 27/06/2004 00:39:22)
AMCReport.exe : version 1.0.2.2 (créé le 15/01/2005 17:13:56)
MediaInfo.dll : version 0.5.1.0 (créé le 11/02/2005 02:24:28)
(appuyez sur Ctrl+C si vous voulez copier ces informations dans le presse-papiers)
OK
BTW have you seen there's a new version of MediaInfo?
CU
What do you do exactly to het this? I always add movies by drag & dropping files to AMC window then importing info from internet...
I did not know that version 0.6 of MediaInfo was released, thanks ;) I hope that it will be easy to integrate into AMC.
About MediaInfo 0.6, it seems to work.
Here is a modified version:
http://www2.antp.be/antp/software/temp/amc3502.rar
scorpion7552
un mystère mystérieux
forget what I have said! Now it works . The strange thing is that when I've got this problem I was running VirtualDubMod (encoding mpeg2 to xvid). I really don't see what the point is, but it is :??: :??: :??:
amc3502 tested. Seems to be OK
CU
