[EN][ES]Suggestions / Sugerencias
javilp
Post by javilp »
[EN]
Well, first of all, I want to thank antp for making this program. It's great. Before knowing it, I had all of my movies in a mess. I took many hours in find a movie I was looking for, in my own bedroom! Now they are all classified and when I want to see a movie, I go to the AMC and that's all.
The only thing that It should be added, in my opinion, is a method to save a list of the movies on a format easily to attach to an e-mail. When I want to send somebody my movie list, I don't now how to do it. I think that, if the print template results could be saved onto a pdf file as well as printing them, or another solution like that, it would be great.
Thank you for all,
Regards.
[ES]
Primero de todo, quiero agradecerle a antp que haya hecho este programa. Es genial. Antes de conocerlo, mis peliculas eran un desorden. Empleaba muchisimas horas en encontrar la pelicula que buscaba, en mi propia habitacion. Ahora estan todas clasificadas, y cuando quiero ver una peli, voy al AMC y ya esta.
La unica cosa que añadiria, en mi opinion, es algun metodo para salvar la lista de peliculas en algun formato que sea sencillo de adjuntar a un e-mail. Cuando quiero mandar a alguien mi lista de pelis, no se como hacerlo. Pienso que, si el resultado de los templates de impresion se pudiera salvar en un archivo pdf ademas de imprimir, o alguna solucion de este estilo, seria genial.
Gracias por todo,
Saludos
Re: [EN][ES]Suggestions / Sugerencias
javilp wrote: The only thing that It should be added, in my opinion, is a method to save a list of the movies on a format easily to attach to an e-mail. When I want to send somebody my movie list, I don't now how to do it. I think that, if the print template results could be saved onto a pdf file as well as printing them, or another solution like that, it would be great.
You can export to CSV, this kind of files can be opened by Excel and other similar programs.
You can also install CutePDF, that will allow to print you from any program (including AMC) to a virtual PDF printer that will produce PDF files ;)
javilp
Post by javilp »
thank you very much
Now I'm doing it with CSV files, but I don't like the format at all, I think it is a little bit horrible to see :hum: .
But I didn't think on the idea of CutePDF, I'll try with it, thank you
CSV is a plain text format, so it does not look very good ;)
